On my 94 GL My driver door is loose, like when you pull it open, it is really easy to pull it open, and once its supposed to be locked open, the wind can easily blow it closed again. This is a pain when I'm trying to work on the dash and stuff, is there anything I can do to tighten it up, because the rest of my doors are fine, pretty tight, and it takes a reallly strong like 30mph wind gust to blow the others closed, but my drivers door is like just a little wind gust will make it slam shut pretty much...so, is there an easy way to make it tighter?
