1 - 13 of 13 Posts
· Registered
I need help. I just bought a 2000 Sable LS and it is equipped with the electronic keypad. Everything I have read stated that there is a sticker on the RAP that has the default code. I looked and the only thing I could find is a sticker that has a bunch of number/letter combinations on it. Is it within these combos that I will find the code? The dealer wants to charge 90 BUCKS for them to retrieve it. Please help!
G
If you bought this car from a ford dealer, they should give you the code otherwise they have no right to advertise the feature and not tell you the code. If its from somewhere else, go to a different ford dealer. Took it to a dealer, the service advisor was under the car for 5 mins, found it and wrote it down for free.
· Registered
Look under the trunk lid, that's where I found the keypad code for my 95 GL. Mine is a small white sticker with the numbers on it, 5 digits.
· Registered
I have a 2000 tauras the same problem
i looked under the dasj and mah at 6 3,240 that was a squeze anyway
i will check the hoot tonight
keep me posted how and where u found it
· Premium Member
mike...your code will be on the white box above the accelerator like many posts have discussed. Remove the box and there should be a black piece of electrical tape wrapped around the box covering the last 3 digits of the code. You need to heat the electrical tape with a hair drier an then slowly remove the tape. It will be a 5 digit bold black code.
call me if you need assistance.
Brad
· Premium Member
Mine was on a sticker in the glovebox. It was inside all the user manual info and such.
-DC
· Registered
Brad
Wow, super. I noticed the black tape around the box, but I didn't think of removing it. I will try it and get you posted.
thanks a lot!
· Premium Member
Mine was on the box above the accelerator pedal. If you are on your back on the front floor with your head right up against the center hump or console (looking back toward the driver's door,) you can see it. You'll need a flash light, but it's there, and it's not covered up or anything. It's a 5-digit code.
· Registered
Talk to the dealer service advisor. Tell him you just got the car and plan on having all the maintenance done there and are looking to build a relationship. In fact you are here today to get the oil changed and take advantage of their free safety inspection (everyone's got one). Oh, and by the way, I have this keypad but no code, I understand it takes about 30 seconds to download this electronically. Any chance of doing this as a favor for a future service customer?
Any service advisor worth his salt will jump on making you happy to get you coming back. If the closest dealer doesn't bite, try it at the next closest one and mention you had problems at dealer A and are looking to build a relationship at dealer B...
1 - 13 of 13 Posts
