1 - 9 of 9 Posts
Does any one know if an exterior door handle from a 96 will fit a 2003?
they look the same. Does any one have any experience, changing them out. Or using one from a different generation?
Doors match, so do the handles.
Just outta curiousity...
Do any other Ford models (besides the Taurus and Sable) share compatible door handles that'd work on the Gen 4?
Nope, just Taurus and Sable handles interchange.
Also be aware that the handles changed in mid-year 2003. '96-early '03 have the same handle, and then late '03-'07 have the later style. Generally, if you have black interior door handles, you've got the later style exterior handle.
I just checked the placard. It was built 2002-09 so it is more of an 02 then an 03 ;)
Chrome int. handles.
OCD Update: Just looked at the placard again. September, no December Doh!
The late 03 to 07 will fit all gen 3 and 4 cars. They will FIT but design wise they are slightly different, the 96 to early 03 have a desighn to them and the late 03 to 07 are smooth and the passenger front has no key hole in it. If u can get a set of those u can switch them all to the smooth style (I like them better). However u will need a early gen 4 or 3 handle to match the design u have.
QUOTE (echarleswhyte @ Mar 29 2009, 09:57 PM) index.php?act=findpost&pid=713479
The late 03 to 07 will fit all gen 3 and 4 cars. They will FIT but design wise they are slightly different, the 96 to early 03 have a desighn to them and the late 03 to 07 are smooth and the passenger front has no key hole in it. If u can get a set of those u can switch them all to the smooth style (I like them better). However u will need a early gen 4 or 3 handle to match the design u have.[/b]
So if an 03 has the passenger side keyhole it's early 03... thanks for the info.
You also lost the rubber gasket that went between the door handle and the body when the door handle went smooth and lost the passenger side keyhole on the 12/02+ built cars.
rubber gasket eh? mm have not seen the new ones up close enough to notice that(I rather not cause a problem looking up close at someones door handles in a parking lot, lol) Maybe that is why they look like they sit flusher with the body of the car (apart from being smooth). Dang now I will be on an ever lost quest to find a set of new handles that are colour matched. Or maybe i can get black ones mmm..........
1 - 9 of 9 Posts
