· Registered
Where is the switch for the door ajar/ interior light located an 97.
G
It's inside the door latch itself. I'm assuming you're having problems with the light staying on. Just spray some WD-40 in there, and you should be good to go.
· Registered
Thanks guys. I sprayed some WD-40 on my latches, all is fine now.
G
Anything that displaced moisture will do the job just fine. I think the silicone spray will work.
What other kind of issues do you have?
