1 - 11 of 11 Posts
Hey guys, I am having a little problem here. The door ajar light is always on on the dashboard, and I tried spraying wd40 in the latch. This did not work. So, I took off the door panel, disconnected all the plugs, buy can’t seem to find the DAS (door ajar switch). If anyone knows where this is, please let me know.
Tire Vehicle Wheel Automotive tire Automotive lighting
Automotive tire Paint Motor vehicle Automotive design Rim
1999 Taurus SE Wagon (dohc, ax4n)
Try something stronger than WD-40. Grab a bottle of PB Blaster, and use the hose attachment to spray it into the lock mechanism. Trigger the latch a bunch of times. If this clears it up, give it a few days then use some white lithium grease on it. I've found on all three of my Taurus/Sable cars and PB Blaster was the only thing that fixed it (I lived with it on the first two). From what I read (I didn't pull the door apart) it's dirt and grime that gets in and jams up the mechanism.
Discussion Starter · #8 ·
Hand Hood Human body Sleeve Finger
Hand Automotive lighting Automotive tire Hood Finger
I took out the door ajar switch and found this… I cleaned it up with some q tips and toothpicks. but the problem persists. I kept the original door ajar switch in there though, and it worked for 30 minutes. Then it went back to not recognizing the door.
1 - 11 of 11 Posts
