Do you get 10% Ethanol Gas?
  • No, Never.
    Votes: 0 0.0%
  • I don't really care if I do.
    Votes: 0 0.0%
  • Yes, All the time.
    Votes: 0 0.0%
  • I have a FFV, so it doesn't matter.
    Votes: 0 0.0%
  • Only as a last resort.
    Votes: 0 0.0%
1 - 20 of 36 Posts
Was just curious if im the only one that does this. When I stop at a gas station when im not familar with the area, I check and see if it has a sticker that says 10% ethanol, If it does, I skip and go on to a different station. My car hates me if I use this gas. Only time ill ever buy any is a gallon to make it to the next station if I need it.
So I dont go to Sunoco, Noco, or Getty.
I usually stop at Kwik Fill or Gulf, Mobil is pretty expencive around here. Or I go to the res for the cheap gas, still better then 10% ethanol for me.
10% Ethanol is a law in Delaware.
Some gas stations doesn't put the sticker, but still sell with 10%.
Not really a choice down here. It's either 10%, 85%, or diesel.
Guess which poll option I clicked. :lol:
eventually everywhere it will be 10% ethanol. and not all stations post that they gas is 10%
The state government forces us to use E10.
In NYS I thought it was a law to post if a station uses 10% Ethanol or not. I go to stations that don't have the sticker, so either their breaking the law or actually dont have the 10%.
Call 1-800-SHO-Z123 to help with your E10 tuning needs. :makeadeal:
I'm not sure if it's actually law, but every gas station I've been to in Mass has pisswater...err...E10.
I voted "as a last resort," meaning, I'm always stuck at a last resort. :p
I always use it...it's about $0.10 cheaper here all the time. I tried the 87 gas once (I understand it offers a theoretical gas mileage advantage) and my car ran poorly (less power & more of a rough idle) ugh. I only got 23mpg on that tank...switched back to 89 E10 and I was back up to 28mpg.
Had I stuck with the 87, my car may have adjusted. I wasn't willing to wait; I wasn't willing to spend more money either. My car has run great on E10 since the day I got it...basically, stick with the gas you typically buy.
the ethanol in the gas will eventually mess something up in your motor.
I use the 10% ethanol too, but I have no choice. every gas station around here has there gas mixed with it
o srsly? :confused:
<div class='quotemain'>
Most of my friends say the same thing. The NCGA may be biased, but they have a page that tackles the many myths of using ethanol in gasoline. It's a somewhat interesting read and can be found here:
http://www.ncga.com/Ethanol/main/your_car.htm
Just the fact that so many automakers approve the blended gasoline makes me feel that I am completely safe using this gasoline. I'm saving money too B)
o srsly? :confused:
except flex fuel motors...
:mj_banana:
I would't worry too much about the 10%. Most cars are designed to run fine with up to 10% ethanol content in the fuel. If anything, it's a high-octane fuel system cleaner, a/f mix leaner-outer thingamajigger.
I wouldn't even know. I'm in Rochester and I go to the local HESS. I haven't seen any signs but then I don't pay attention beyond grab the '87' hose. Suse's running good on it and it's her 2nd fill since I had her. My old 1987 Pontiac 6000 ran fine. So I don't know maybe there's no E10 in it maybe there is.
Then again, in my Pontiac, I always added all kinds of goofy additives like STP Gas Treatment at least once in the winter months, and STP Fuel Injector Cleaner in the spring/summer. I always add those right after filling the tank though.
Anyone know if I should still add that stuff in my Taurus? It's not a classic car so I'm not sure if she needs it or not.
I've been using E10 gas since the early 80s. My Fords still all rust away from under me.
Just made a trip to Calif for a wake, found alcohol free gas in some places in AZ and NM. Truck mileage went from 19 to 23 for those tanks.
1 - 20 of 36 Posts
