I have a 94 Taurus GL, with the stock Transmission cooler in the radiator.
A week after I got the car, I had a slight leak <_< from the radiator from where the bottom tansmission line enters the chamber, a little tug on it with a wrench and it stopped (not much room to do anything else)
However, a few days ago, I noticed two small (about the size of a silver half dollar each) marks under my car every time i park it :blink: , just assumed it was slightly more coolent, and put some stop-leak in.
The problem has not gone away :angry: , the other day, I parked on concrete, and noticed that the puddles are red, instead of green....
I got under there, and noticed a slight drip from the steel line coming from the transmission, right where it feeds into the bushing on the radiator, just on the outside of where i had to play around with the coolent leak.
My question is this. Should I try to replace those lines and bushings? or should I just bypass the Tranny cooler altogether, and install an aftermarket one, (such as a Hayden 1404 or the sort)
Im not overly concerned with which one will be easier or harder, I'm just more concerned about getting it fixed by whatever method possable.
