Is there any way to disable all of the lights that come on when I press the unlock button (keyless)? I've already removed the DRL relay. I would prefer it if absolutely nothing came on, unless I wanted it to. This includes the interior dome light when I open the door, the puddle lights, and the running lights.
Thanks guys!
AFAIK, no. Those functions are controlled by the GEM/SJB. I have never heard of anyone being able to reprogram it.
Could always put a relay (or really 2 since each side is on its own fuse) in the power feed to the headlights so the lights would only turn on with the key in RUN. Could all be done under the hood using key on power for the relay coil.
