Ok, a little backround first. 2003 Taurus with 3.0 Duratec and 82,000+ on original transmission. Regular maint / fluid & filter changes done to the transmission with a Gen2 SHO trans cooler installed and a cyberdyne 0-300 F digital temp gauge. The SHO cooler is mounted under the front core support and the flow goes from the trans to the radiator cooler, bypassing the stock cooler to the SHO cooler then back to the trans.
Today I took the wagon on its longest trip with the Gen2 SHO cooler and the gauge togeather. It was a 130 mile run @ 70mph with an outside temp average of about 30 F. I got on the highway and set the cruise control @ 70 for the complete trip. Once on the highway the trans warmed right up to 112F and stayed steady for most of the trip. What was interesting to watch was on up and down hill sections you could actually watch the temp go up and down by as much as 2 degrees plus on the up hills and minus on the down hills. The engine temp stayed normal the whole trip with pleanty of heat.
It will be interesting to see how much this will cool come summertime. If anyone is thinking of installing a cooler and temp gauge, I would highly recomend the digital gauge. You would never see this temp change with an analog gauge.
