1 - 1 of 1 Posts
Hey Guys, this thread lists different types of DIY Diagnosis scan tools together with their features and prices. You may check and find out the one you need.
Now you can enjoy 10% off with Promotion Code:10YDS4GU (Expired on Aug 17th)
Just enter the shop!
Amazon Shop: https://www.amazon.com/s?marketplace...&redirect=true
Product: TD 300 Price: $15.99
Amazon: https://www.amazon.com/dp/B07D4GT911
Functionality of reading& clearing codes, checking I/M readiness, reading VIN and turning off check engine light (MIL), this car diagnostic scanner also offers over 7000 code definitions on the user’s manual to help DIYers and technicians perform car diagnosis much easier!
Product: TD 309 Price: $19.99
Amazon: https://www.amazon.com/gp/product/B07DQG2LG4
【ACCURATE OBD DIAGNOSIS】: You can find out emission problems by viewing fault codes with explanations, read I/M readiness, and clear codes to turn off MIL with super ease from the car diagnostic scan tool, saving your time and money.
【REAL-TIME DATA RETRIEVA】L: This car diagnostic tool supports quick viewings and retrievals of freeze frame, VIN and other information anytime and anywhere.
Product: AL 200 Price: $33.99
Amazon: https://www.amazon.com/gp/product/B07DGN4155
【MIL TURN-OFF】OBD2 code reader TOPDON Artilink200 supports reading and clearing codes stored in vehicle ECU about partial Engine and Transmission faults, and it makes great sense in the check engine light turning off after the maintenance
【I/M READINESS CHEKING】 The I/M readiness status checking works on the sensors related to emissions, checking the sensors’ running status to figure out whether your vehicle pass the emission test or it’s time to have your vehicle maintenance
【DATA RETRIEVAL】 Freeze frame data retrieving checks the certain vehicle conditions which are recorded by the on-board computer at the time the emission-related fault occurs, and vehicle identification number retrieving helps users identify vehicle information.
Product: AL 201 Price: $33.99
Amazon: https://www.amazon.com/dp/B07D4F5M5W
【EXCLUSIVE DESIGN】: The AL201 scanner features large LCD screen, I/M hotkey, 3.6 foot long diagnostic cable, user-friendly function menu and graphing display to make OBD2 diagnoses and result analyses a piece of cake for you
【HELPFUL EMISSION TEST】: The OBD2 supports one-click I/M readiness, O2 sensor test, and on-board monitor test to help you quickly and correctly confirm your vehicle’s emission status to avoid getting the ticket for exhaust excess
【EASY MIL TURN-OF】F: You can easily find out the problems with the Diagnostic Trouble Codes and their definitions offered by the OBD2 scanner, and clear them to turn off the Check Engine Light (MIL) yourself to save money
Product: ArtiBattery 101 Price: $53.99
Amazon: https://www.amazon.com/gp/product/B07DDDDSK9
【EXTENSIVE COVERAGE】 Test cranking, charging, and common fault for all automotive cranking lead acid battery including ordinary lead acid battery, gel battery, AGM flat plate and spiral battery.
【EFFICIENT TEST】 Directly detect the bad cell battery and remind you of replacing; test the battery with loss of electricity, no full charge needed.
【TESTING STANDARD】 Compatible with the world’s majority of battery standard - CCA, BCI, CA, MCA, JIS, DIN, IEC, EN, SAE, GB.
Product: Topdon Plus CAN Price: $59.99
Amazon: https://www.amazon.com/dp/B07F6F4BRG
【ALL-AROUND OBD2 FUNCTIONS】 This diagnostic tool is characterized by complete OBD2 functions including Reading/Erasing Codes, Live Data Stream, Freeze Frame Data, O2 Sensor test, On-board Monitor Test, Vehicle Information and more, to greatly improve the efficiency in car detection.
【3 PRACTICAL FEATURES】 This TOPDON Plus2.0 has 3 commonly-used functions for saving time and money: DTC Lookup – to know codes definition directly; MIL Turn-off – to be accomplished by erasing DTCs; I/M Readiness Status – to pass the smog test after making sure the emission-related systems are alright.
【SIMPLE INFORMATION RETRIEVAL】 In addition to obtain vehicle current running status from the readable live data with graph, this OBD2 scanner also supports printing freeze frame data via PC which shows the codes and parameters stored when the accident occurs for further quick repair and maintenance.
Product: Topdon Elite CAN Price: $107.99
Amazon: https://www.amazon.com/dp/B07DQGWHY3
【ADDITIONAL ABS/SRS FUNCTION】 Read and clear ABS/SRS for most 2006 and newer cars, including 24 mainstream models: CHRYSLER, FORD, GM, ACURA, AUDI, BENZ, BMW, CITROEN, HOLDEN, MINI, PEUGEOT, PORSCHE, SEAT, SKODA, VOLVO, VW, HONDA, HYUNDAI, INFINITI, KIA, LEXUS, MAZDA, NISSAN, TOYOTA.
【OBDII FULL FUNCTIONS】 Supports OBD2 full functions for most 1996 and newer OBDII/CAN compliant US, European and Asian cars, including read& clear DTCs, read data stream, turn off MIL&reset monitors, view freeze frame data, check I/M readiness monitor status, display O2 sensor test data and retrieve vehicle information, etc.
【BUILT-IN DTC LOOKUP】 Enables you to quickly find the malfunction without checking on Internet, this easy-to-use diagnostic tool comes with built-in DTC look-up, which provides you with detailed diagnostic trouble codes definition in English / French / Spanish/ German.
Product: ArtiDiag 100 Price: $399.00
Amazon: https://www.amazon.com/gp/product/B07D9F46NM
【SPECIAL FUNCTIONS】 with reset, service and adaption capabilities, TOPDON auto scanner can finish electronic parking brake(EPB) reset, steering angle sensor (SAS) reset, oil reset, DPF regeneration and BMS reset, besides, special functions IMMO, Injector and ABS Bleeding enables you to perform more advanced car diagnoses.
【All system diagnosis】 android-based of this full system diagnostic tool Offers a full access to all vehicles and variety modules diagnosis for reading and clearing codes, live data
【Thoughtful combination】 supports Benz and BMW with optional proprietary adapters, it is unnecessary to buy additional adapters at a high cost
1 - 1 of 1 Posts
