Is there any benefit to replacing my old original 130k+ fuel injectors with ones of a higher flow rate?
You won't see any gain in power from the larger injectors alone. You might see more power and a better, smoother running engine from installing new injectors because they are perfectly clean and have perfect spray patterns. Unless you're using a power adder such as a supercharger / turbo / nitrous, you don't need larger injectors, they are of no use unless you have a way of burning the extra fuel.
