1 - 14 of 14 Posts
Hey guys,
I hate to say this but I think I may have messed up my car :( I turned her on for the first time since doing a car wash about a week ago today and she died. The only things I did to her since then were repair battery cables (battery is fine), spray an undercoating under the car, and clean the IAC valve. The reason I cleaned the IAC valve was because of her habit of revving forward when I would be at stoplights or coasting.
To clean the IAC valve I sprayed throttle body cleaner into the two holes and drained it back out multiple times until the drainage was clean. Then I left it overnight with a dry rag over the holes to let it dry out.
Today I turned her on and she rattled some then died. The check engine light came on. I had read that the sensor in the IAC valve has to reset itself and the light will come on at first so I just started her up again and she ran a little longer, shakily, then died. But the light didn't come on. I did it again and revved the gas a little and she stayed on for a good 5 minutes, so I drove her around the block, she made it through stopping at the stop signs for a few seconds but didn't sound healthy, kind of a puttering sound and feeling. When I got back to the driveway, which is uphill, she died again.
So I'm thinking an idling problem right after I screwed with the valve has to be the valve. Should I buy the new IAC valve and replace it myself? I think it's only like $50, I can handle that. Or should I tuck my tail in and go to the dealership? I guess realistically this is all my fault, but I researched a lot and really thought I knew what I was doing when I did this...
Any advice would be immensely helpful,
Thanks
the $50 may be worth it, get some CRC electrical cleaner and spray the bit that goes to the iac, let it air out, reconnect it
from what i heard before i replaced mine was throttle body cleaner will mess it up... may have heard wrong though
I've always heard that Taurus IAC's are not really cleanable without a high risk of damage.
I would just replace the IAC, since a trip to the dealer will cost at least $100 for them to just let you breathe their air.
K, I'm going to call the local NAPA store tomorrow and see what they've got, hoping to save myself shipping time. I checked Rock Auto, they've got a $40 one, "t-series," the price is really appealing but I start to wonder what makes it so cheap and there's no picture.
I'm guessing I did mess up the sensor. Cleaning it was just wishful thinking to save money on the whole part but I won't be going that route anymore. Live and learn I guess ;)
You should be able to go to NapaOnline.com and check the parts available for your local Napa store. I can do that for mine.
i've never had problem cleaning mine out with throttle body cleaner. i do mine every oil change and haven't had a problem yet.
Just buy the Motorcraft part through RockAuto. I have enough experience to know that most aftermarket IAC valves act like an OEM one on the fritz.
+1
Spend the $$ on a Motorcraft replacement, not cheap junk.
I have cleaned IACs with some success, but sometimes had to replace them when cleaning them did nothing.
Discussion Starter · #10 ·
Well damn. I was debating between rock auto and napa, I ended up calling the local napa store this morning and they're ordering me one. I hadn't seen these posts yet. I just thought if I could pick it up it would save me shipping $$ and they can get it for me tomorrow. I really need to get my taurus put back together and running asap so I can go get my new hood (couldn't get it home so I need to go to the seller and install it in the parking lot real quick). I can't really go back on my word to napa. Hopefully it won't be an "on the fritz" part, it comes with a warranty at least.
Thanks for the answers though!
Discussion Starter · #11 ·
I got my new valve today and installed it and the car idles great now. It's a napa part but it comes with a one year warranty and it's made in japan, usually good stuff comes from there. I put some sealant on the metal then made the screws snug but not too tight. Problem solved :) Thanks for the help.
didn't it come with a new gasket? just curious becuause you kinda make it sound like it didn't...
the one i got from o'reily's (optima? i'd have to dig the box out) works great, just a bit "iffy" here and there cause i broke part of the connector while replacing it...
Discussion Starter · #13 ·
It came with what I thought was a piece of cardboard shaped like the opening. Maybe that was the gasket? I didn't think anything of it because when I removed the old one it was just metal glued to metal with two screws holding it in place, nothing different in between. Maybe I should take it off and put the cardboardish thingee in between the metal?
that was probley it... mine looked like cardboard with a slight cotton-ish feel/look to it... i hear that when you take off your iac the old gasket has a tendency to rip or disinagrate, although my old one came off in one piece...
1 - 14 of 14 Posts
