I was prying out my right side halfshaft from the tranny and it moved outward about 1/2" to 3/4 inch and then I noticed, stupid me, I hadn't taken out completly the control arm to subframe bolt, so the strut/wheel assembly couln't move outward with the halfshaft.
Will this damage my inner cv joint/halfshaft? I don't know if the internals have play in them or not laterally but I'm hoping they do.
The inboard joint has about two inches of travel in it.
Whew! That makes me feel better.I have enough to do swapping the tranny without worying about a busted halfshaft. Thanks for the reply!
No problem, good luck with the trans swap!
I leave the halfshafts attached to the spindle. I unbolt the 3 strut bolts at the top. unbolt the 15/16 strut rod nuts at the front of the subframe, and unbolt the controll arm at the frame. then unbolt the 2 12 mm calaper bolts and zip tie it to the chassie then remove everything as one really heavy ass assembly.
the bob has seen me. i'm 125lbs of furry and I can still manhandle it. If you are a girly man you can remove the rotors to make it lighter but this will get everything out of the way and it takes about 25 min a side to get everything out. Just make sure you mark the strut towers so you can put the struts back where they were.
