Actron OBDII scanner
Hey all, I just ran across this smokin deal on an OBD2 (on-board diagnostics) scanner at Advance auto parts. This scanner reads and displays check engine lights, clears codes and it even monitors engine sensors while driving (Air fuel ratio, speed, throttle position, RPM, engine load and so on). The cheapo $60 ones DON'T do this. They only give you a code and then you need to hop online and retrieve what it means; they also don't clear the codes.
Now some of you are wondering "I'm not a mechanic, why do I need this?" Well, if you've ever taken your car to the shop and have them scan it, it usually costs 1hour labor. That can range anywhere from $75-105.
So what it would normally cost you just to get it checked you can buy a scanner and do it yourself.
The best part is it works on ALL cars from 1996 to present. The tool is updatable so if you get a newer car, then this tool won't become obsolete.
So, if you've ever had a check engine light come on your car, this little tool is an invaluable resource. You can see what it is yourself, and even clear it.
Just thought I give you guys a heads up.
PS: It's on sale right now, $30 off.
