The 1st place that I would check would be the fuse box (NS). In case you dont get the problem solved soon may I suggest you do what I did a few years ago in a Buick I had? When my DL's went out I just taped a small cheap flashlight to the steering column to illuminate the dash, It wasn't as good as the dash lights but at least I could see the speedo at night. Good luck to you!
Do they just not work in extremely cold weather?
Is it just the instrument cluster illumination that doesnt work or do ALL dash lights not work, like light switch / dimmer control illumination, radio night dim, clock dim, etc. If OZNLY the actual instrument cluster lights dont work, but others do, it is NOT a blown fuse.
