2002 3.0 DOHC VIN S......
CAR HISTORY.... car has new e3 spark plugs and new motorcraft wire's
p0303 cyl missfire
and missfire at startup code.
cyl 3 missfire, cyl 3 located at the rear at the transmission side
pulled intake and checked wire and plugs agin swap wires at coil reinstalled intake and ran cleared codes ran diag still cyl 3 miss removed intake and swaped plug and wire with #1 and #3 cyl reinstalled cleared codes and rand diag still #3 missfire removed intake and installed new coil from store reinstalled and ran diag still missfire #3 removed intake and removed injectors #3 and #6 swaped resealed reinstalled, ran diag still #3 missfire pulled intake and #3 plug ran car sound like good compression, and put plug in wire and ground good spark on #3cyl.,,, removed valve cover and inspected valve's and spring cam's all looked good. reinstalled all compoents and still #3 missfire
i will paypal 5 dollar's to anyone that get me a solution without just replacing parts
im thinking it could be the inj driver on #3 is bad i dont know how to test for that thought,
thank you for your help
p0303 cyl missfire
