The cruise control on my 99' SE Wagon works intermittinly, the cruise light comes on but when I press the set button the light starts flashing and still other times it works fine. Any ideals?
Could be so many things, Short, relay, sensor, error. I would try the easy stuff first. The fuse, which is probably fine since it works somethimes,. however could be some dirt, or something causing a short. Then check the relay, and the switch etc.
I was incorrect the cruise only comes on when I push the set button, when the cruise does not work the light will flash a few times and then nothing. Any help?
There is a self test that can be run on the CC system, but I forget the exact procedure. I believe it is posted somewhere on this site.
