I had the shifter cable replaced in my 2000 Mercury Sable about two weeks ago and haven't had an opporunity to use the cruise control until this week. I found that it doesn't work at all.....no green cruise light nor does it engage. What can that be in relation to the shift cable replacement. If anything.......I want a little advise to take back to the garage that did the cable. Thanks in advance for any and all advise you may have.......
Check the black box located on the driverside strut tower, it will have a cable running to the engine. Make sure that the wiring is still plugged into the box.
QUOTE (3RDGEN @ Jul 3 2009, 11:36 AM) index.php?act=findpost&pid=736738
Check the black box located on the driverside strut tower, it will have a cable running to the engine. Make sure that the wiring is still plugged into the box.[/b]
Yeah I checked the plug. I actually pulled it and replugged it and it is not the problem.....thanks for your help.....
