I've searched around and can't find anything relating to my problem.
My 94 sable with 91k miles and Essex 3.8 has a bad idle. It will start fine but it idles like crap. The rpm's will drop and then the idle returns to normal. It will clear out for a bit after the rpm's drop, but then it starts idling like crap again, and eventually stalls. I've looked all over for vacuum leaks and can't find any. I sprayed flamable carb cleaner over the fuel injectors and all gaskets on the lower intake manufold. I also cleaned and oiled the idle valve and cleaned the air flow meter. None of which made a difference. i also disconnected the battery for a while and it still did the same thing.
Anyone have any suggestions of what I should be looking for?
Thanks!
Thanks!
