21 - 29 of 29 Posts
· Super Moderator
Originally posted by saerandy@Jan 24 2004, 11:56 PM
Here's the whole assembly with sensor at the top.
wow, that is completely different than the SHO. mine goes over the end of the cam journal and thats it. that looks like a distributor!
Thats because the Vulcan had a distributor from 86 to 95. When the Vulcan went DIS in 96, using the old dist hole in the block was an easy way to pick up a CMP signal.
· Registered
At the dealer it is about 350-400 dollars to replace the whole thing. They are known to go bad.
If you are fairly handy and mark things well you can do it yourself for the part price only.
Stick with the Motorcraft part.
· Registered
QUOTE (ZZman @ Jan 16 2009, 12:08 PM) index.php?act=findpost&pid=692979
Stick with the Motorcraft part.[/b]
Wow, here in Florida, the Ford/Lincoln Dealer wants $500.00 Labor and $130.00 for the parts to replace this part on a 2003 Taurus ses!
They said they have to open the manifold to change out this part... Is that correct?
Thx...
H.
· Registered
QUOTE (Qwertz9586 @ Jun 28 2009, 11:40 PM) index.php?act=findpost&pid=735839
No manifold removal isn't required on the Vulcan.[/b]
Thanks for the quick reply...
I just hate to think they are blowing smoke but you never know...
There must be something justified to ask for $500.00 labor for this install plus additional for the part...
Is there a technical report or manual on the process? I need mine changed as the car will just stop running when you light throttle the accelerator...
H.
· Registered
I'm not sure if this is the problem with my 2004 Taurus SE (Vulcan) but I think it might be. I hear a sound similar to the one that the other posts, with the sound, shows but not all the time, so I was wondering if this is the problem would my car throw any codes? I hooked a scan tool up to it but got no codes. I've checked the spark plugs, the fuel system, and changed the fuel filter and its done nothing to help my car run better. So basically I was just wondering if the cam synchronizer and sensor is the problem or if maybe somebody else knows what could be wrong with it
· Super Moderator
Replace the syncro shaft assy now before it fails, the oil pump stops working, and its new engine time. While the CKP itself may be good at the moment, it makes sense to replace it along with the syncro assy while you have it apart.
· Premium Member
QUOTE (hmeister @ Jun 29 2009, 12:12 AM) index.php?act=findpost&pid=735850
the yacht payment, the alimony payment and they figure you dont know any better.
i got the parts from genuine ford parts . com for 130 out the dooor
H.
21 - 29 of 29 Posts
