Hello.
Lately i've noticed that the weight between the accecories belt and the crank is mobing backwards and farwards. I dont think that this is right because she used to stay in her place in the past. also in the cabine i hear it moves, and it happanes when i press the gas and the crank is moving faster.
i woud like to know if the weight (wich is a round palte) suppose to move or just roll. and if the crank sensor is really their, behind it.
Thank you very much!
Should not be wobbling. There should be a key and a bolt holding it securly. Sounds like the key way has widened due to looseness.
You need to take the crank pulley off and see what is going on.
Thanks!
But i also wish to know what is the pruppose of this "disk" or wheight?
What does it do?
Thank you!
