I really need some help! Have a 1994 GL 3.0 gas and the cooling fan will not come on when the car gets up to temperature. It DOES work when the A/C is engaged, at both speeds. A/C off-fan goes off after a few minutes.
Have replaced IRCM (twice) with re-built, Temp Sensor (old one tested good). Have tried to trace wiring and re-run the ground to the body. Car runs great but overheats!!!
I am at a loss and the Haynes IRCM wiring diagram is not accurate, so if any of you guys have any ideas, they would sure be welcome.
