Hi,
My son has a 2002 Taurus. The vehicle was overheating and the temperature gauge would spike after a short drive and the coolant would boil over and leak out through the top of the overflow container even though the cap was still in place.
I replaced the thermostat and that did not help the situation.
I then changed out the radiator. Once I changed the radiator I no longer get any indication of a cooling problem from the gauge. The gauge starts out below “C” and then gradually reaches about the midpoint as I am driving along. However while driving I can smell hot coolant and at times I also get the condition where the coolant boils out through top of the coolant recovery tank (I think that is the proper term) when I stop even though the cap is still on. Even when it does not boil over I can see that it is quite hot. Because of this I have only been taking short test drives because I am concerned about damaging something.
I checked the hoses that I accessed while changing the radiator and can find no leakage.
After changing the radiator I filled the recovery tank with 50/50 coolant to the cold fill level. Was there something else I should have done with the new coolant? Is there another fill location that I can't find?
The only thing I have not put back after the radiator swap out was the plastic valance beneath because I am thinking I may still need access underneath to figure out what is going on.
As you can probably tell I am something of a novice at this so any and all ideas and/or suggestions would be appreciated. I just can’t figure out why the coolant would be boiling out yet the temp gauge says we are rolling along nicely.
The pressure cap of the degas tank is known as being a weak point, especially if it is old or an after-market part. Try replacing that first.
Overflowing when turning off the engine means that the system is not staying pressurized.
+1 on the overflow bottle cap
When a system is properly pressurized, the boiling point of your coolant is greatly increased.
Since the taurus has no cap on the radiator, its most likely the cap on the degasser / overflow bottle. (or some other leak in the system)
Fine cracks on the bottom of the degas tank have also been found to be a cause of boil over. Do not use a replacement tank made or distributed by Dorman. They are junk.
Hi Folks,
Thanks all for your replies. I have a new Motorcraft cap on the way from Rockauto. Hopefully that does it. I will update the thread once I give it a whirl.
