okay i need some info, or step's on how to go about replacing the front lower control arm bushing.
it's the bushing's the goes into the front frame.
it's for my 1991 sabel 3.8.
okay my dad think's it'll be very difficult, to replace, but both of em are oil soaked so it should be that hard.
right??
okay so any of you peep's know how to go about doing this???
if you can please let me know a.s.a.p.. . . .
thanks!!
First you need to determine if the bushing can be replaced separately or if you can only replace the entire control arm.
Sometimes you can use an air hammer to drive the bushing out or use a ball-joint/u-joint press or even a large c-clamp and a couple of large sockets.
if u are jsut replaing hte bushing then it can be cut out by using and old kitchen knife though the center hole.
eather was it is jsut going to be a pain bc all the bolts are rusted into place.
actully it's the rubber bushing that is in the front sub frame, autozone did'nt have it, so i have to call the daeler, . . . . .
help??
If you go to Federal-Mogul You can find out Moog's part numbers. Then go to Rock Auto to get the parts. Use discount code: 138798145045 in the "How did you hear about us?" field to get 5% off.
