Rockauto lists a rear and a front lower subframe bushing.
Is there not a front upper bushing?
I'm confused.
The rears are sold individually. You can and should use the rear bushings on all corners. AutoParts123.com is even cheaper than RockAuto.com.
Why "should" you use rears? Less subframe movement? Why not just get the aluminum bushings, then? Better turn-in, and they're cheaper.
The rear bushings are more beefy. Alum Bushing have no give and will provide better turn-in, but also transfer vibration and noise.
