1 - 15 of 15 Posts
Alright well i have a Compaq Pesario S4020WM and everytime I go to a website other then this one and a couple select other it brings up some stupid stuff....like for example i go to www.google.com and it comes up with this http://start-page.info/?error=www.google.com
Well my question is, How do you reformat a computer :rolleyes:
I know on my really old HP it took a disk, this one didn't come with a disk and a while ago i called compaq and they said they can send me the disk but i dont need it because it's already on the computer....
I already tried to do a system restore but it didnt work....anyway to wipe the whole thing instead of setting it back to an earlier time?
Thanks in advance!
head up to compusa and buy a program i think its called quick disk. just ask one of the guys there. i will reformat the whole drive, or u can just have someone do it for u. the problem with doing it urself is its easy to mess up the drive peramiters. just my 2 cents
grrrrrr...compusa is like...10 minutes from here, and it's like 10pm....
stupid fandangled technology! why can't it be as easy as it was 6 years ago!
edit: Sorry, I'm upset lol......Thanks Lucky, i'll probablly go there tomarrow...
ya i just got done reformating mine, if i were u id get a apple, my G4 is perfect, none of the problems my Windows POS has.
If i had the money for a Mac, believe me i'd definetly buy one, but $2500 for a computer i mean c'mon now....lol that'd be a nice down payment on a 2004 Taurus :ph34r:
I think if you still have your Windows CD that came with the computer if you bought it new you can simply relaod Windows. That will wipe out everything including all of your saved files and programs you have added. I think that's a little extreme however. I have done that a couple of times however, started everything from scratch and rebuilt, but it's a pain in the :moon:
The problem is living with people who don't save stuff....and tend to misplace....i searched all over the house for it, and no luck....
I hate when that happens!
They say your Windows CD is on the HD? Or are they saying you don't need the CD because Windows comes pre-installed? What if the HD fails, and you need to start from scratch?
You can just borrow a copy of your version of Windows, if you can get your CD-key.
Well, if you're going to reformat you might as well first try to solve the problem. What you got is a trojan on your computer that screwed around with a ton of your registry settings. I've been infected a couple times by something similar. I'll contact you on AIM and try to help you get rid of it.
Discussion Starter #10
Thank you so much for your help Xee!
you dont have to reinstall your computer for gods sake! lol
Ok, there are many different variations of this lil spyware program..
but in mose cases, you can get rid of it by unchecking it in startup (type msconfig under run, go to startup), then delete the application itself (not just the shortcut) in the startup folder under programs/startup.
Also, you might need to type regedit in run in the start menu, go to edit, find... type in start-menu... click on find... then continue with F3 -- every instance found in you registry, delete it.
I think this should do it. : hamal :
The more recent versions of this trojan (CWS) are a virtual pain-in-the-ass to remove manually. Just download the program CWShredder at www.spywareinfo.com and it'll take care of it in 99% of the cases.
Don't get me started on Spyware, Jessie. <_< I've seen more kinds than I know what to do with at work. And now I'm starting to see polymorphic spyware.
Yes, polymorphic spyware. It changes it's image name upon every reboot, even if you delete the current instance. Some of them have a daemon running in the background that will restart the process with a different name if you terminate it! :blink:
It's gotten to the point where programs like AdAware and SpyBot just don't get everything anymore. I have to sit there with HiJackThis and similar tools to try and evaluate what hooked into where, and how to get rid of it, as well as any parent processes. :angry:
1 - 15 of 15 Posts
