1988-1990: No data
1991: 3.8 Head gaskets, Pressure Feedback EGR sensor, MAF sensor, Transmission Clutch Piston, Brake
Booster, Heated windshield module, Constant Control Relay Module
1992: 3.8 head gaskets, MAF Sensor, PCM, Transmission Clutch Piston, Heated windshield module,
1993: 3.8 head gaskets, Pressure Feedback EGR sensor, MAF sensor, Blend door actuator, Windshield wiper
system, Constant Control Relay Module
1994: 3.8 head gaskets, EGR passages (SHO), MAF Sensor, Constant Control Relay Module
1995: 3.8 head gaskets, MAF sensor, Constant Control Relay Module
1996: DPFE and CPS
1997: DPFE, PCM, SAI Pump, TRS, Door Ajar Switches
1998: CPS, Restricted EGR passages (Vin "S"), DPFE, PCM, SAI Pump, TRS, Door Ajar Switches
1999: DPFE, Restricted GR passages (Vin "S"), SAI Pump, Antilock brake module, Door ajar switches,
Daytime running light module
2000: DPFE, Restricted EGR passages (Vin "S"), SAI Pump, Door Ajar Switches, Flex Fuel Sensor module
(Vin "2"), Brake Deactivator switch for cruise control.
2001: DPFE, Restricted EGR passages (Vin"S"), SAI Pump, Door Ajar switches, Flex Fuel Sensor module
2002: DPFE, Blower Motor Resistor
2003: Fuel pump
2004: Fuel pump
2005: no common problems listed
2006-2008 No data given
**And they didn't mention it much but the infamous Cam Position Synchronizer/sensor for many years.
DPFE: Differential Pressure Feedback EGR (DPFE) Sensor
MAF: Mass Air Flow sensor
CPS: Cam Position Synchronizer/sensor
SAI: Secondary Air Injection
TRS: Transmission Range Sensor
PCM: Powertrain Control Module
MSN Auto isn't the best automotive website out there. I don't really see the point of posting that list here. If people want to go read it on MSN, they're free to go do that. It's most likely not going to go away anytime soon. However, it won't help much since it's just a list of problems with no solutions. We already have a knowledge base on how to fix the problems if someone is looking for a specific answer to an existing problem.
It may give people some insight as to where to look for a problem if it is common since they may not know what the specific problem or solution is. Also why would they go looking for this information on MSN auto? This is information specific to Taurus vehicles so why shouldn't it be on a Taurus site? Knowledge is good....... :)
**I also think that Topic finder link should somehow pop out and should say something like:
LOOK HERE FIRST!
LOOK HERE FIRST!
Common Problem Finder Engine
It's alright, you can thank me later. :thumb:
