All you need is:
It's possible, but time consuming.
- floor console w/ brackets
- floor shifter
- shifter cable w/ bracket
- lock-out actuator
- column shroud
there is no droop, its literly shredded.If you can access the droop, you can spray the cloth with some 3m Super 77 and tack it right back up. Just make sure to stretch it back on tight and keep it under pressure for a little while.![]()
