Ok, upon farther reading i realized that i should probably check the passages for carbon build up before i replace any sensors. The car does have 271 000 km, so i wouldnt be surprised if there was a carbon build up. Now, im not sure what exactly to clean. Here are a few questions i have:
1. Are these the two passages that i have to clean? The ones that the red arrows are pointing to? One going to the EGR valve from the exhaust and another going to the engine intake.
[attachment=28791:egrvalve.JPG]
2. Can i clean these by taking the EGR Valve off (ive seen some ppl say they cleaned it by taking the throttle body off, but it seems like too much work and unnecessary.)
3. And how do i take it off? Just undo the bolts at the top and the ones at the bottom?
4. Will i need 2 new gaskets? One to the engine intake and one to the valve exhaust intake?
5. And is there anywhere else i should clean? Any other tubes or passages?
Another thing i wanted to mention is that i did the test that i read about in the other topics, where u suck air from the valve to see if the engine dies down and comes back to normal and it does it just fine. Also, i tried sucking on it while the engine was stopped.
6. I sucked as much as i could and waited for 20 seconds, and the tried again and still couldnt suck anymore air, so this means that theres a perfect vacuum, no leaks anywhere, correct?
7. I cant find the DPFE sensor and i looked everywhere. behind the intake, behind the engine on the left and on the right and cant find anything like what people have been showing on this forum. I did however notice 2 metal pipes sticking from the exhaust tube that goes into the EGR Valve, which were connected to a sensor via rubber tubes. This sensor was very small however, about the size of a box of matches, and was only suspended in the air around the middle of the back of the engine. Is this the DPFE sensor on my car?
Thank you for all your help.
