1 - 2 of 2 Posts
Getting that pesky check engine light again - code P0301 Cylinder 1 Misfire.
I've tried replacing the plugs, swapping wires around to see if that's the problem, and I still can't figure it out. Could it be the coil? If so, how would I definitively test that?
Thanks for any help. :)
Ok I dont know much about cars, but I had the same problem, mine was a plug though, did you check to see if your plugs needed to be spaced properly with a gap tool ? Mine didnt seem to neet to be spaced at all
Anyway I dont know that much so its probably not that simple :(
1 - 2 of 2 Posts
