My engine light has come on so I ran some codes to see what the issue is. Here is the code;
P2272 O2 sensor signal biased/stuck lean (bank 2 sensor 2)
Does this simply mean that the O2 sensor is bad, or could something else cause this to react this way?
I would say you may have a bad vacuum leak that is feeding the front side of the intake manifold.
^^^^ +1000
Nasty vacuum leak.
Exhaust leak near O2 sensor
Contaminated or failed HO2S2 (Sensor 2)
HO2S2 wiring/circuit problem
Loose installation of HO2S2
Fuel pressure incorrect
Faulty fuel injector
Engine coolant leak
Faulty purge solenoid valve
From the internet search for P2272.
Engine coolant leak
Check Engine light on with no code. What should we do? visit this site to get answer
Another reason is PCM which has failed
