· Registered
I started my car up the other day and turned the lights on. The speedo, tach, gas gauge, and climate control lights do not light. The clock is also so dim I can not see it. I checked the fuses and they are all fine. Any idea what the problem may be? The dimmer switch still turns on the dome light when you click it up. Thanks for any and all support.
· Premium Member
I think it might be the dimmer switch...the odds of having all your cluster lights blowing out at the same time is pretty rare indeed
· Premium Member
The dimmer switch only controls the lights for the tach, speedo, fuel/temp gauges. This way, you can control the amount of glare coming from the instrument cluster when driving at night. The warning and turn indicators aren't attached to the dimmer as they are meant to function all the time.
