everytime i hit a bump decnt sized one . the back end i hear a clunk sound like somthing is loose .. or frozen only seems to happen when its below 50 degrees. any ideas was thinking maybe rear sway bar end links sounds like its coming from the around the rear struts
is there a diagram or picture of end links where they are and how to change them on the rear end of a 99 taurus
you got diagram or how to for both
Click on the Topic Finder at the top of the page and scroll down to the section labeled "Suspension". You will find much useful information. If you are only going to replace rear end-links, one trick I have not seen posted is to use your floor jack to push up the end of the rear sway bar to get clearance to get the end-link in place.
