1 - 9 of 9 Posts
my cigerette lighter doesnt work to well so i planned on putting in one that had 4 out lets...and i was going to cut the wires from the stock one and wirer in the 4 outlet one...but there is a yellow wire and a light blue with a white stripe wire that go into the same thing not sure of the purpose of 2 wires in the same place but o well...then there looks to be a big ground like 2 seperate black wirers coming together and plugging into the outside part of the lighter....o and the yellow and light blue on plugs right into the center of the lighter...so whats + and - because the 4 outlet one only has 2 wirers and the stock one has 4....which wirers go where
the 2 ( the yellow and blue with white stripe) plug into the center. the other one ( looks like 2 black wirers that come together) plug into the outside steel shield like thing. the 2 black ones are the biggest and the other 2 are the same size...and what light?
Don't know what the yellow wire is. It is not in the Ford diagrams. The two black are the grounds and the light should be a dark blue and white wire. The light blue and with wire is the one you want.
so what ones are + and - becuase thats all i need to hook this other thing up. i just need to know which ones are + and -
umm ok...so can the ground work as a - and witch one is + the blue one? i dont think you really have answered my question or mybe you have but can you just say + is this...and - is this..sry im not the best electrician in the world just wanted some help
QUOTE
Don't know what the yellow wire is. It is not in the Ford diagrams. The two black are the grounds and the light should be a dark blue and white wire......[/b]
If you read the above statement the grounds are the two black wires. Take your pick.
1 - 9 of 9 Posts
