i installed my chip today and did everything correctly i belive and when i went to start my car it wouldnt and the theft ligth started a slow blink. i did a scanner check and the car was communicating with the scanner. i dont know what to do can someone help me>>>
Before you installed the chip did you clean the metal tabs on the PCM? If you dont clean the "goop" off the tabs to where they are copper looking then most likely you are not getting a connection. I purchased an Apten Chip and it did the same thing.....but my problem is because my PCM was reporgrammed and does not match the original code.
yep everything was done correctly it just doesnt work.
Did you buy it directly from a dealer or did you buy it from another owner?
If you bought it from another owner the PCM codes may not match.
i bought it brand new from american motorsport
ok......send him a PM and let him know whats going on and he can help you more directly on what to do. His name on here is americanmotorsport.com
He is VERY helpful!!! He has helped me with my problems and its an Apten Chip
