What specifically triggers the check fuel cap light?
The system measures fuel vapor pressure through a couple of sensors. If it has set a check fuel cap light and no other codes, then the readings it got were consistent with a lack of seal at the fuel cap.What specifically triggers the check fuel cap light?
First step is to check the fuel cap, in particular the gasket and where it seals for dirt and damage.I do have a small evap leak but not a large. Code 657 I think at time of the light. Yes 456 and 457
The gas cap didn't seam loose when I checked it, but I suppose it could have been. I have recently noticed a drop in my gas mileage. Is there a chance the two could be connected?
This page explains the earlier version of the system on a CV, but it's very similar on your car.What specifically triggers the check fuel cap light?
It's not likely.I have recently noticed a drop in my gas mileage. Is there a chance the two could be connected?
Today we read from the Book of Troubleshooting, Verse 24: Excessive fuel consumption:It's not likely.
