21 - 23 of 23 Posts
Discussion Starter #21
Hi guys thanks for that info. i was under there doing an oil change and can see the no clearance as the ABS gear is right above where you would need to put grease fitting and to have to take the axel out to do that then why not just replace BJ !? like all mechanics there great in some aspects / areas but no-one can know it all as i did suggest the needle & said it does not get it force into the joint area but its better than nothing to fill the boot area so will look into doing that again Thanks all
I have used one. But I pop out the taper and slip the needle between the boot and shaft and put in one shot of grease. Tie rod ends easy. Once the boot rots you can only add some here and there to buy time. Works.
Discussion Starter #23
Thanks if i understand did not go thru the middle of the boot that would be round if full of grease ? so you went from top or bottom of boot & filled it that way ?
21 - 23 of 23 Posts
