1 - 11 of 11 Posts
My front main seal is leaking.
Is this an easy fix? Is it as simple as pulling out the crank pully and changing it out?
I swear, I thought I made a topic like this, but I can't find it. Maybe I just mentioned it in a post in another topic somewhere, I can't remember and the search turned up nothing. Only thing I could find was when I posted pics of all the crap going wrong under my car.
Nope, that's your oil pan gasket. Vulcans had a tendency to do this. You'll need to remove the starter and the y-pipe, then the oil pan, and replace the gasket. Depending on the condition of the y pipe it may or may not be an easy job.
If Rudy says it, it has to be true. :)
I forgot to add, check your PCV valve when you do this too. On the few I've repaired, a couple of them had plugged PCV valves, which may or may not have caused the gasket creeping problem. Not really sure, but it won't hurt to check.
Oil pan gasket is really easy. The hardest part is getting the Y-pipe of the rear exhaust manifold and getting to the O2 sensor connectors. After that, it's cake. I did mine a couple weeks ago, and with two people it took under two hours, and most of that was struggling with the Y-pipe, since one of the studs was stuck.
Oh, well what do ya know, it is the pan gasket. I just saw a round seal poking out near the crank pully and didn't think for another second. Now that you say it I realize that's part of the pan.
Well, I already knew that the pan gasket is leaking in other spots, so there is less work to do than I thought to prevent my oil from leaking. That Y-pipe will be a pain in the ass though. Luckily, I just changed the bolts going through the Y-Pipe flange so I don't have to deal with severe rust like I would othewise have had to.
Will the new gasket I just put in still be good? And is the gasket that sits between the Y-Pipe and flex tube the same as the gaskets that go between the headers and the two ends of the Y-Pipe?
and I can only assume that the PCV valve is in bad shape. I've never had it changed and I bet when I bought the car it hadn't been changed in a while. That's an easy fix.
BTW, how much do PCV valves go for? I figure it can only be a few bucks, right?
Well, I already knew that the pan gasket is leaking in other spots, so there is less work to do than I thought to prevent my oil from leaking. That Y-pipe will be a pain in the ass though. Luckily, I just changed the bolts going through the Y-Pipe flange so I don't have to deal with severe rust like I would othewise have had to.[/b]
If you just changed the bolts at the bottom, its possible you'll have some problems at the manifold.
Will the new gasket I just put in still be good?[/b]
It should be, provided you don't accidentally mess it up.
And is the gasket that sits between the Y-Pipe and flex tube the same as the gaskets that go between the headers and the two ends of the Y-Pipe?[/b]
No, there are no gaskets at the ends of the manifolds, they should be just flanged. And they are NOT headers, they are exhaust manifolds.
I can only assume that the PCV valve is in bad shape.[/b]
not necessarily
BTW, how much do PCV valves go for? I figure it can only be a few bucks, right?[/b]
yes
I've taken a look at them before. They've got some rust, but they looked in tact, unlike the ones at the flex tube, which were so corroded that I couldn't get a wrench on them, I had to cut them out.
I know. I just always seem to interchange the terms. When I had a lot less knowledge (when I was like, 12 I think) I thought they were all called headers. So it kinda has me stuck in the habit of calling them headers instead of exhaust mainifolds.
Wondering it it would make sense to go into a muffler shop and get the studs and nuts renewed so you can drop it and bolt it back up at home.
Whoops. Somehow I posted on a real old thread. But how about it? What’s the best way to deal will 15 year old exhaust systems?
Sounds like a great idea to have the shop guys fight it for you! Rust and broken bolts are a giant pain in the unmentionables...
Of course, if the shop is going to get the exhaust off, I think I might just pay them a few bucks more to do the pan gasket while the oil pan is exposed, rather than taking it back apart when I got it home.
1 - 11 of 11 Posts
