does anyone know how to change all the dash vents on a 96 sable? the 2 defroster vents are pretty easy, im just unsure how to change the rest, any help?
I did this already in my car. Just go ahead and get a flat tipped screw driver and insert it between the vent and the dash, then pull the vent out by moving the screwdriver up and down like a lever, this should give the vent a bit of slack so it pops out.
If you need any more help, I'll gladly post a video on how to do it.
sorry, been working all weekend, thanks for the help, im going to the junkyard to get some new vents, and i will try that, thanks again. if i need more advice i'll post
The ones in the dash pad are easily removed by inserting a small flatblade between the thumbwheel and prying outward to release the pin. The ones in the instrument panel CANNOT be removed this way. You must remove the instrument panel first as they are fixed from behind.
