I finally changed the fuel filter on my 03 SEL today.
Not much of a problem, thanks to you guys and especially with the correct clips I got at NAPA (NCK11).
Have a different problem now......
Code P1223 came up, Fuel Pump Driver Module Off Line.
Has this has happened to other people when using the "disconnect the wire from the inertia switch and run the engine till it dies method" to relieve fuel line pressure?
Is this a problem or normal due to the above used method?
Can the code just be cleared or should I leave it? :)
I changed my filter a couple of months ago and did not get this code. I also disconnected the inertia switch in the trunk.
You can probably clear the code without any issues.
I've never disconnected the inertia switch. I just uncouple the fuel lines from the filter. Not that much gas comes out at all.
I unplugged mine and ran it til it stalled too...3 different filter changes...never got that code. :dunno:
