1 - 9 of 9 Posts
I just purchased a 2002 Taurus SES. The previous owner said that it had a six disc in dash CD player. It has a CD player, but I can't figure out how it is possible to load more then one disc in it. I bought the car of ebay and did not get a owners manual with it. Any help would be appreciated.
Thanks
Is there any way you could take a picture of the faceplate?
You could also look online for a copy of the owner's manual. Try using google to search for one. You might also be able to find a copy on ebay.
Also, welcome to the club...
JR
**Edit** 500th Post!
If your car has a 6 disk changer, it would be in the trunk.
Mine looked like it could load in dash 6 disk, but that’s not it at all...
It has a button called I tune and on top it says 1-6 disk,
But I tried everything; I used to work for a car audio shop... I even went there and had them check it out, nothing.... but I did order a manual off ebay for 5$. I’m waiting on that.
I checked the trunk etc. etc. The guy that sold it was not real knowledgeable about the car...I think he saw the 1-6 disc on the CD player and assumed that it was a stack type player. I down loaded the owners manual of the Ford site it says in the trunk, glove box. I am now sure that from what you have all said that this is just a standard CD player...I do not understand why Ford has the 1-6 disc switch on the player...oh well, I still like the car. I will say this it is sure a high revving little engine, I have the 200 HP, I noticed that there is no red line on the tach, is the engine rev limited? Or does it just run right up to 10,000 RPM;-)
Thanks for your help.
It says that because it can control a 6-disk changer.
As someone else said, the faceplate can control a cd changer. The changer would be a six disc changer, and you would use the 1-6 buttons to change which disc is selected in the disc caddy.
JR
02 Taurus CD changers are in the center console (if you have that) or in the trunk (if you have column shift). They are not in the dash like other Ford models.
1 - 9 of 9 Posts
