I want to do the tape aux input mod, but I am not sure if my Tape cassette player works. Because when I tried to use the tape adapter, It jus spits the tape out and give a TDE2 error or TDE3 Error and If the tape adapter does go into the tape deck it give the same error and when I press eject it says "no tape" and does come out unless I turn the radio on and off. Also I cant find a regular tape because well it 2009 and no many people use them anymore. So Just In case cassette player, dont work. Is there another mod I can do that cheap without spend over $40.
There aren't any other cheap solutions. You can try replacing the control panel or you can buy the PIE adapter that hooks up to the CD changer port in the back.
FM transmitter.
I plug my mp3 player into this FM transmitter. No tape player needed. You can use an SD card, flash card, or MP3 player. (It sounds okay. It will never sound better than your FM radio. If you like the way your radio sounds, this will probably work for you.)
http://www.dealextreme.com/details.dx/sku.10130
