1 - 16 of 16 Posts
· Registered
I got this Sony MP3 CDman with the car kit.... was working fine...
Now I guess I am having a problem with the cassette adaptor?
when I put this cassette adaptor the right way, the stock audio (GEN 3) tape deck play fine for a few sec, then changes direction (to side 2)... then again back to side 1 then so.. finally says "TDE" and goes to radio.
regular audio cassettes work fine?
I first felt that the spools on the cassette adaptor were to tight.. so i ripped it open & reassembled.. it work fine for a few days...
then again now the tape deck reverses side after a few second.
what makes it reverse direction?
· Registered
ya i was abt to buy a new adaptor. But the spools on the one I have are pretty loose to turn by hand.
Also the is a belt beside the head on that adaptor. that contacts the capstan and the roller i guess.
What If i remove this belt from the inside.. also for the adaptor to work are the two spools and the gear between them necessay... After all there is no tape!.. just a head on the adaptor that contacts the head in the tape deck.
· Registered
I can't tell you how to fix it, but I did have a similar problem once getting a cassette adapter to work on a rental Lumina. I would stick the adapter in, it would play for a few seconds, reverse a couple times like you said, then spit it back out.
G
I had that problem w/ my Gen3 - the only adaptor I could get to work was a $20 or $30 one from Radio Shack. It was the "Radio Shack" brand. Might want to try that.
· Registered
Discussion Starter · #8 ·
30 bucks!!
I saw for one at walmart for like 7-8 bucks... besides this sony adapter worked well for like 2 months...
the adapters you guys have.. Do you see a belt beside the head? that could contact the capstant.
Previously i had an adapter that had like a small wheel that would contact the capstan/roler on int he tape deck
G
Now that I think about it, you can have the Radio Shack adaptor I have - provided I can find it - for just shipping cost. I bought it a few years ago, I think that's why it was so expensive, lol.
· Registered
Discussion Starter · #11 ·
seems to be working fine. besides I have a thing for sony stuff. I guess others might not have a good head...
anyways will let you know if I get the problem again, which should be only a few days... thx
· Registered
Discussion Starter · #14 ·
hey vulcan,
yup, crack it open.. most of the are sealed.. but you can use sometime like a flat knife to rip it along the seam.
just remove everything except the two spools & the center gear & the spring loaded head.
now the adaptor will work so long as your deck plays side one..
(top side)
· Registered
It didn't work...I think its worse now. But then mine didn't have any belt it had gears I had to remove....and the only ones I removed were the ones that turned as a result of the pincher. I left the others in intact so the spools would turn each other. Oh well....I'll be investing in a new stereo soon I guess.
1 - 16 of 16 Posts
