my car at high rpms vibrates and as i recall it has also done it at low rmps in higher gears(refering to 3rd and 4th). could it be my engine mounts? and if so how would i tell.
thanks
jorsh
Have someone rev the engine while in gear and with the brake on while you watch the motor. Any movement over an inch or so is bad mounts.
You do not have to give it much gas to do this.
the tauri's are known for motor mounts, but also could be tires out
of balance. does it do it at idle-in drive? cold or hot? or only in high
rpm's? just a thought but on mine it was only hot and even in idle
at DR, so i'm thiinking maybe water pump or oil pump? can you feel
it in the steering wheel?
