1 - 2 of 2 Posts
:ph34r: Need help my 01 Sable keeps going off with the alarm at a drop of a pin, for no cause what so ever. Any clues as to why? Can I disable this function?? Help me this is driving me krazy..... :angry:
well, if no one has mentioned...Welcome to the club!
id advise doing a search before you ask questions on the fourms as 99% of topics have been covered many times both in the fourms and archives.
As to answer your question....heres is a list of things that could cause it starting from most likely to least:
Hood pin swich (Very common problem, located on the drivers side fender.)
Trunk pin swich (Sable models only, not sure if they kept it on the gen 4's)
Door swich (usually the dome light will stay on as well)
It is most likley the hood pin swich, its a high falure item....and a cheap fix.
for now, just disconnect the wire from the swich and see if your problem returns.
Brad
1 - 2 of 2 Posts
