Stats: 92 taurus L,3 liter v6.
History- Got it last year and after a new water pump, refurbished rad and what not was working fine up untill the other month.
PROBLEMS- Last month the car started leaking rad fluid shortly after it had been turned off. Sometimes only a small drip and other times it was a liter or more SO I tried stop leak and the leak stopped. So a week or so after stop leak the top rad hose blew open on me so I replaced with a new hose and filled the half empty rad with water cause I was broke and since then it seems to be ok aside from smelling the left over stop leak and rad fluid burning smell which is not that bad.
Ok what's bothering me is knowing WHERE the original leak was coming from. If you were standing in front of the engine then the leak was coming from the left side underneath the belts somewhere leaking down onto the engine pan or whatever it's called SO im wondering if that's the water pump maybe?
Im hoping it's just the water pump and or seal(don't bloody well know enought to know)and I can just replace along with a new bottom rad hose and reservoir along with a good flush and be done with any cooling problems.
Lastly how do I MYSELF give the cooling system a good flush?
Please advise with detail;)
;)It might be your expansion tank leaking,the white tank on the left side near the alternator, my '02 was doing the same thing that you describe. I had to replace it. I understand that these tanks are prone to cracking. Advise to get a new one if yours is bad because used ones are not to be trusted. I ordered mine online from carstuff.com. Cheapest price i could find. good luck! I forgot to mention that tank would seemingly go a few days without leaking then suddenly coolant on the ground in this area. by the way the expansion tank replaces the coolant overflo tank in the taurus they are prone to cracking because they are under pressure. pardon my grammar
That stop leak is total crap. Try draining your radiator and see how plugged up the draincock is. :thumb: Whenever you have a leak, check the hoses (including the reservoir tank hose) and don't trust stop-gap solutions.
