Can someone tell where cam sensor Is located on 2007 Taurus, and what needs to be removed to get to it...
Thanks, Marc.....
It sits above the cam sync which sits in the old distributor hole radiator side of the throttle body.
There is a big rectangular plastic wire run sitting more or less above the sync / sensor that has to be pushed / pried out of the way to get to it. Likely the plastic wire run will crack when moving it out of the way but that really isnt a big deal.
  • Like
Reactions: sheila
