Does any one know if i can put a 2001 ax4n Transmission in a 1999 Taurus that used a ax4s using a early 1998 pcm for a duratech engine/transmission?
New Transmission is same bell pattern
AX4N and AX4S are mechanically the same but are hydraulically different, therefore, they are controlled differently.
On top of that, not only are you crossing years, but you are crossing Generations. I think you'll have more trouble than it's worth. You're better off finding a matching transmission. The wiring and PCM is more than likely completely different.
