1 - 1 of 1 Posts
In TSB nomenclature I definitely have the "ISSUE", the ticking noise from the left bank cylinder head on my 01 Sable (78k miles).
I followed the "ACTION", that is with the engine running I increased the tension on the water pump belt tensioner. I expected the ticking to go away for some reason, but it got louder.
So I guess that verifies I should do the "Service Procedure".
However I found in the archives a TSB that supersedes TSB 04-20-8.
Does anyone have a PDF of the new TSB?
QUOTE
Engine - Left Bank Cylinder Head Ticking Noise
TSB 06-3-5
02/20/06
CAMSHAFT TICK NOISE - 3.0L 4V ENGINE ONLY
FORD:
2001-2005 Taurus
2001-2006 Escape
MERCURY:
2001-2005 Sable
2005-2006 Mariner
This article supersedes TSB 04-20-8 to update the vehicle model years and Service Procedure.
ISSUE
Some 2001-2005 Taurus/Sable, 2001-2006 Escape and 2005-2006 Mariner vehicles built prior to 1-17-2006 equipped with the 3.0L 4V Duratec engine may exhibit a ticking noise from the left bank cylinder head, with the engine at normal operating temperature only.
ACTION
To diagnose, with the engine running and warm (normal operation temperature), using a mechanic's stethoscope determine if the ticking noise is coming from the left hand intake camshaft at cylinder number 6, (Figure 1). If the ticking noise can be verified, refer to the following Service Procedure.
SERVICE PROCEDURE
1. Remove the left bank valve cover. Refer to Workshop Manual, Section 303-01B.
2. Rotate the engine clock wise until the cylinder number 6 intake cam lobes are pointing up and the valves are fully closed.
3. Remove all left hand intake cam caps individually and reinstall them finger tight.
NOTE THE CAMSHAFT CAPS MUST BE COMPLETELY LIFTED OFF AND THEN SET BACK INTO POSITION. LOOSENING AND RE-TORQUEING CAP BOLTS IS NOT SUFFICIENT.
4. Torque bolts in sequence shown in Figure 2 to 72 lb-in (8 N.m) excluding cam cap number 8L camshaft cap.
5. Using a screw driver positioned on each side of the top of cam cap number 8L (Figure 3) apply hand pressure and shift cam cap number 8L toward the exhaust side of the cylinder head.
6. While holding cam cap number 8L in the shifted position, torque the fasteners number 9 (inboard) first, to 72 lb-in (8 N.m) then torque fastener number 10 (Figure 3).
7. Install the left hand camshaft cover. Refer to appropriate Workshop Manual, Section 303-01.
8. Fully warm the engine to normal operating temperature to verify the repair.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
060305A 2001-2003 Taurus/Sable: 0.9 Hr.
Remove And Install The
Camshaft Caps Includes
Time To Remove And
Install Valve Cover (Do
Not Use With 6007A10,
6250AL, 6584AL)
060305A 2004-2005 1.0 Hr.
Taurus/Sable: Remove And
Install The Camshaft Caps
Includes Time To Remove
And Install Valve Cover
(Do Not Use With
6007A10, 6250AL,
6584AL)
060305A 2001-2006 Escape and 1.2 Hrs.
2005-2006 Mariner:
Time To Remove And
6250AL, 6584AL)
DEALER CODING
CONDITION
BASIC PART NO. CODE
6A267 07[/b]
1 - 1 of 1 Posts
