I am looking at a 2004 Ford Taurus. The owner said it threw off the cam sensor code. They replaced it but the light is still on and the engine idles rough. Does anyone have any ideas? Could it maybe be the crankshaft position sensor or the cam syncro? Seems like a good deal if I could make sure this isn't a major problem.
there was another member here that had that code pop up. after cps and syncro replace it threw the code again. turned out to be a crank sensor gone bad. not saying this is the case but its worth a look.
I guess the question I should have asked is. Is there anything that is a major deal breaker that can throw a camshaft position sensor code?
Could the syncro alone through the code?
Thanks
My guess is the syncro or the crankshaft position sensor but I don't know as much as the others here!
well... if the cps was replaced, was it aligned? a bad snycro might make noise. iirc the oil pump will fail if the syncro goes.
Cam sync hasnt been replaced yet, just the cmp (sensor) on top, so no alignment necessary. My guess is the ol po340. Maybe a fubared cam sync? Car prob. wouldnt start with a bad ckp (crank position sensor).
